The Razer Blade Stealth are a line of premium Ultrabooks by Razer. The latest model is the Razer Blade Stealth (2019)
48вопросов Показать все
How do I tighten the screen hinge?
I’ve had 2 of these computers, having to return one because of a few serious issues. However, the second one I received is significantly less resistant in its screen hinge. A small shake will move the monitor very easily, whereas the first computer had very solid hinges.
How can I tighten the hinge?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hi!
Have you dissasebled the laptop? Or just replace the monitor from the bad one.Or change the laptop if you have warranty
Hope this helps
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
paulha1195 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 996
