What to Check for on 27" Thunderbolt Display with no Backlight
Greetings folk, here is another one for us today:
I got this 27” Thunderbolt Display for less than $50 with no backlight.
The LCD is up and running with the flashlight test but here is the interesting part that makes this one unique: I don’t get any backlight upon connecting the thunderbolt cable, not even a flash.
Is it possible that this is still the same issue that is fixed by bridging some 3.3v connection on the LED driver IC?
I can use the speakers, ethernet, and webcam, so it’s not an issue with the cable and there is no visible damage to the logic board.
I am looking for a quick list of things to check, thanks for any and all comments!
Timothy
Это хороший вопрос?
This answer might be useful Low light or no backlight on LCD
из Voromax
I've seen so many of these and I still can't figure it out either. I've even replaced the Backlight driver and it didn't do anything. If you bridge a connection you will get full power to the backlight but you won't be able to dim the display.
из Anthony
