Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1623вопросов Показать все
MacBook stuck on white screen after update.
Hey good day, My Mac Book Pro is stuck on a white screen with a question mark after i tried to update it. Any idea what could be this issue?
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
Your likely hitting the classic case of a bad HD SATA cable. I do recommend you replace it before doing anything more as the more you access the drive the more likely you’ll corrupt it to the point it won’t be recoverable. Then you’ll end up needing a new drive as well.
Here is the part you’ll need MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable and here’s the IFIXIT guide you’ll need to follow: MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable Изображение
Продукт
$34.99
Был ли этот ответ полезен?
Оценка 2
Наиболее полезный ответ
The question mark folder means that the computer can’t find an operating system to boot too. Sounds like either the update failed and corrupted your installation or your hard drive died during the update. You can try holding command r while booting to boot to recovery and see if you can use disk utility to repair your disk. If that is unsuccessful, you can try erasing your drive and reinstalling macOS if your drive is still good. If you have data you need to recover, you can boot the Mac into target disk mode by holding t (Before you wipe the drive) and using a firewire or thunderbolt cable to connect it to another Mac and copy off the data.
Оценка 2
Добавьте свой ответ
MICHAEL JABARI NELSON будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 352
