Blue lines in de top corners of my screen
There are blue lines in the top corner of the screen. What is causing this and what can I do to make it better?
Это хороший вопрос?
Это хороший вопрос?
Frits you can’t fix this. This is a failed panel. The only way to repair your TV is by replacing the panel. These will be hard to find. Remove the back from your TV and take a look at the panel. There should be a label which identifes the maker (Vizio is not choosy, they use anybodies panel) and the model of the panel. Use those numbers to try and find a replacement
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 202
