Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
275 Questions Показать все
Why are so many phones starting to copy the iPhone X notch?
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
2 Ответов
I wonder the same question. I have no experience with this kind of phone notch, but according to what I read , I think that the main reason is : “The divisive screen design is also visible proof that your phone is the very latest model, too.” source : https://www.engadget.com/2018/05/02/lg-g...
Был ли этот ответ полезен?
по рейтингу 0
The issue is the screen real estate you could have lost if they just cut the whole edge off. Keep in mind the face ID system is using about 1/2 of the space so if you drew a line just under it and made that the edge of the screen you would still need space for the signal bars and battery level items which would have then pushed down into the workable screen area down still farther, Ouch!
Here the signal & battery icons are within the unused space the face ID does not use. But, the edge of the workable space then could be still under the face ID area or also encompass the other space as well.
Frankly, I think it’s a bit of a distraction and if I could I would limit the useable space as being below the sensor not including it. But Apple thought differently! If you look at the copy cats you’ll see they only use the space for the icons not the working screen for everything else.
по рейтингу 0
Добавьте свой ответ
Nancy Ericsson будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 29
