Why is the washer heating my cold water wash cycle?
If I put my washer onto a cold/cold cycle, my clothes still come out hot. I even shut off the hot water inlet going into the unit to prevent this. Could this be a ATC problem?
Это хороший вопрос?
Это хороший вопрос?
Sounds like you're getting hot water from the cold water inlet. This could happen if the water hose connections have been reversed. Try running on a hot cycle, if I'm correct the water will be cold.
Был ли этот ответ полезен?
I will try this tonight - crazy how something like this could possibly be so simple. Thanks very much!
Occam's Razor - The principle is often inaccurately summarized as "the simplest explanation is most likely the correct one." But it works.
Thank you. Will check this out. Never even thought of that!
sounds like your mixer is bad. I had that happen and just turned off my tankless water heater to get cold water when I realized my mixer was bad
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 4,243
