The Logitech Performance MX Mouse is a premiere mouse from Logitech with darkfield tracking technology and a free-spinning scroll wheel. Released in 2009. Model number: 910-001105.
I got this mouse from goodwill I dont have a receiver
So, I found this mouse in a goodwill for 4 bucks.I noticed that it doesent have a reciver but a micro usb in the mouse. I figured that its a charging port for the battery. i wonder, does the micro usb serve as a “alternate mouse connection to the pc to make it work?”
Thanks!
(also the mouse works when i put a battery on it.)
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
The USB was designed to recharge the battery only.
But if you want to make it as an “alternate connection”, you will still need a receiver plugged into the PC. And you do not need the battery if you have it permanently on a USB cable.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Dude Thank you! it really helped!
из
Thanks, it helped you.
из
No it doesn't
It need the host Bluetooth conductor to function in any way
But luckily you can reprogramm it to work using any other receiver If you have any
Счет 0
2 Комментариев:
and another one
the mouse is using a unifying software
i did some reasearch and i found out that the logitech reciver is a unifying so it works in any logitech device ordered the receiver. waiting it for it to arrive.
из
great
that sound great
из
Добавьте свой ответ
Zander Castillon буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 23
За всё время: 279
