iPhone 8 Plus Backlight/Black Shadow Problem
Hey!
My iPhone 8 Plus has a black shadow on the right bottom corner of the screen after I changed the LCD Screen. Could this be a bad Backlight IC? If yes where is the Backlight IC on the motherboard and would changing it fix the problem like it does on the other iPhones. Couldn’t find anything on the internet for the 8 plus regarding the issue I have.
Thanks,
Fahad
Update (08/27/2018)
I checked the motherboard and turns out the pin 45 was bad on the J5700 connector. So I flipped the board to check the fiter/fuse and the small C5733 is bad. What do I replace it with?
Это хороший вопрос?
