Occupying second RAM slot leads to laptop not booting
Laptop: ASUS F510UA
The Laptop is actually a Vivobook F510UA. They didn’t have my selection so I choose the closest one to it I could find.
I'm trying to install a second RAM stick into my laptop however anytime I try to boot with the second RAM stick installed, my screen will be blank/black. I know it has to do with the second RAM slot because I did some test that prove it isn't the RAM stick. Original RAM stick is single rank 8gb, aftermarket ram stick is Crucial dual rank 8gb. Both Crucial and Samsung RAM sticks are DDR4. I'm pretty sure this doesn't matter but I put up the information just incase anyone ask.
Test 1: Slot 1: Samsung RAM(Original RAM Stick) Slot 2: Empty Result: Boots fine. This was how the computer originally came.
Test 2: Slot 1: Samsung RAM Slot 2: Crucial RAM Result: Power button light boots but screen won't turn on.
Test 3: Slot 1: Empty Slot 2: Crucial RAM Result: Power button light boots but screen won't turn on.
Test 4: Slot 1: Empty Slot 2: Samsung RAM Result: Power button light boots but screen won't turn on.
Test 5: Slot 1: Crucial RAM SLot 2: Empty Result: Works fine.
Test 6: Slot 1 Crucial RAM SLot 2 : Samsung RAM Result: Power button light boots but screen won't turn on.
Basically anytime the slot 2 RAM is occupied, the system wont boot up.
Because of these test I suspect that it has to do something with the second RAM slot. Is there a settings I have to change in order the be able to access the second RAM slot or do I have to change anything in the software side before I am allowed to use the second RAM slot?
Just did a reset on the bios to default and the screen still wont turn on.
This is my first time trying to upgrade a laptop and I have little to no expreience with these types of things so if there is a solution, please be clear and very thorough with the instructions given. Thank you.
The Picture attached is of the Crucial RAM stick in Slot 1 while the Samsung(Original RAM) sits by Slot 2(Not inserted).
Это хороший вопрос?
