Thin, light and powerful with incredible sound and Wi-Fi capabilities is what everyone needs to have on the go.
42 Questions Показать все
Replace the WiFi antenna
I had a repair done on my laptop and they cut the wires to the WiFi antenna.
Do you have instructions on how to replace the antenna? I would not trust them with my laptop again.
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
1 ответ
Sorry to hear you had a bad IT experience.
The wires for the antenna you can usually find for that laptop pretty cheap. The front digitizer can be popped off.
You can do so by taking a thin flathead screw driver and prying around the edges of the plastic bezel and the back LCD cover.
Take a look at the antenna part and see if there is a part number or model to do a search and find one of the exact same model.
Был ли этот ответ полезен?
по рейтингу 0
Добавьте свой ответ
John Palinkas будет вечно благодарен.
Просмотр статистики:
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
За всё время: 344
