Media sound not working? SOLVED
Media sounds not working. Notifications & system sounds are fine.
Это хороший вопрос?
Это хороший вопрос?
Also another thing to check is to make sure you do not have do not disturb turned on or turned on as scheduled. Depending on how it is setup it may mute all media sounds.
Был ли этот ответ полезен?
Thanks. It started working after I left it off for an hour.
Thanks... checked and it was my “Do Not Disturb” mode was on. Don’t know how it got enabled but it was in and fixed my problem.
If your tablet is anything like mine when you hit the volume keys there is a dropdown, maybe the media tab is all the way down.
Alternatively you could have somthing wrong in the system. I had a problem like this where i had to go to a boot menu and clear some temporary data on the
Thanks. It started back up after I left it off for an hour.
Make sure it is not connecting to a Bluetooth device
Thank you thank you thank you Malcolm, that was the solution for me. My tablet was connected with my hearing devices, which lay around somewhere in the living room.
За последние 24часов: 1
За последние 7 дней: 14
За последние 30 дней: 88
За всё время: 22,011
9 Комментариев
Thanks for the input guys. It's loud & proud again.
из Richard
It's working again. Needed some down time I suppose. It's loud and proud once again! Thanks
из Richard
Sounds goes up and down by itself
из drury.stephen
I have a problem of my new tablet A. It has no sound, i can’t hear any voice . All is set in settings but still no voice
из Monlisa Lim
I waited on my comment to be answered..
из Monlisa Lim
Показать 4 больше комментариев
