Half of the screen is black
Screen has no *serious* physical damage (no cracks), but half of it is black. Touch screen works (including the black part of the screen).
What’s the problem and how to fix it?
Это хороший вопрос?
Это хороший вопрос?
Hi @icecom ,
Has the tablet been dropped or gotten wet at all?
Connect an external monitor to the tablet's mini HDMI port to check if it shows a full display.
If it shows a full display then you have either got a video flex cable problem, a video flex cable connection problem or a LCD display panel problem.
If the external monitor's display also shows only a half screen display, then you have a GPU/motherboard problem in the tablet.
Here’s a link to the ifixit Nvidia Shield Tablet guide which may be of some help in opening the tablet so that the video flex cable/connector can be inspected if you have determined that it is not the GPU that is the problem.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 39
За всё время: 3,395
