Right bumper only works when pressed very firmly
So the problem that I am having with my controller is this. When I depress the right bumper like I normally would it doesn’t seem to work. When I say “normal” my finger typically rests on the outer 50% of the bumper and typically no further towards the midline of the controller. Only when I press it very firmly is the signal then conveyed to the Xbox. In comparison, by pressing down the left bumper on either of the very edges (as well as the middle) the signal is properly conveyed as it should be with just the normal amount of pressure required to depress the bumper. If I had to estimate I would say that it requires roughly 3 times the pressing force to activate the signal from the right bumper in comparison to the left.
At this point I am past my warranty and have already decided to take the controller apart to see if I could locate the problem myself. The levers themelves leading to the tactile switches look to be identical on either side leading me to believe that they are not responsible for the issue. My question then becomes what is the likliehood that it is the tactile switch itself that is the problem? Is there a possibility it is anything else that could be the culprit? Any assistance would be greatly appreciated!
Это хороший вопрос?
23 Комментариев
I had this problem too on the 1708. The single piece of plastic that makes up the bumper was fully intact. I did rub the sensor quite a bit with rubbing alcohol on a q-tip, press the bumper a bunch, and let it dry for a couple days WITHOUT the battery attached.
из Jim Thomson
It’s happening with my series 2 elite controller it’s so annoying and during this quarantine I can’t go to game stop to get a replacement
из heribertolagaresjr
Same i dont know how to take it apart or fix this and i mostly play gta which is heavily reliant on rb. I thought microsoft would fix the bumpers on the elite series 2 but they dont seem to care
из Skixz
Yes it is very annoying as I too play gta. It’s one of my main games to be honest and it’s so annoying and difficult having to put extreme pressure on the bumper when your trying to drive and throw sticky bombs etc.
I may take it to a repair shop near me soon when it re-opens and if they can fix it I will let this small group know if they still want to know.
из Owyn Hicks
Hi @Jim Thomson did you have to take the controller apart to get to the sensor to apply the rubbing alcohol?
из Owyn Hicks
Показать 18 больше комментариев
