SSD upgrade 2018 model
Hello,
Is it possible to upgrade the SSD in the latest MacBook Air (2018) model, or has Apple soldered it making this impossible?
Thanks…
Это хороший вопрос?
Hello,
Thanks…
Это хороший вопрос?
The 2017 model uses the exact same design as the 2015 model. The only difference was an upgraded CPU chip as Intel stopped producing the chip Apple was using.
Here’s the IFIXIT guide you’ll need to follow: MacBook Air 13" Early 2015 SSD Replacement and here’s the needed SSD [связанный продукт отсутствует или отключен: IF123-123]
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 3,727
3 Комментариев
There is no 2018 model as of yet. The most current model is the Early 2017 13"
из Dan
Thanks Dan!
From what I understand from the demo below, a 2017 13"'s SSD should be replaceable; do you agree?
Thanks...
из David
Yes you can replace it with either the OWC SSD or the custom Apple SSD designed for your system.
из Dan
