Updated version of the 2016 Retina MacBook. Model A1534, EMC 3099. Now features faster Kaby Lake processors up to 1.4 GHz Core i7 with Turbo Boost up to 3.6 GHz and up to 50 percent faster SSD, and supports up to twice the memory.
81вопросов Показать все
Is deleted BootCamp partition recovery become possible macOS Sierra?
I have accidentally deleted bootcamp partition on my Mac computer using disk utility because windows 8 has been damaged or corrupted while I try to resetting it. Note that I wasn't using bootcamp assistant to install windows 8. I managed to make my drive into a single partition but when I press alt/option on boot, I still can see the windows boot option and the data stored in it. How to repair my Mac hard drive so the windows boot option disappear?
Please tell me any solution on how to restore the BootCamp partition data back to my Mac hard drive and regain access to it?
Это хороший вопрос?
Оценка 3
Добавить комментарий
2 Ответов
Наиболее полезный ответ
You can take the help of a Mac data recovery software that provides deleted or lost BootCamp partition recovery features. Also, avoid using the Mac machine to make sure that no other files gets over-written on that Mac hard drive.
Был ли этот ответ полезен?
Оценка 2
Sorry to say its not recoverable ;-{
When you deleted FAT32/exFAT partition and make it part of your GUID partition that did you in. A BootCamp install is a bit different than a raw Windows install which is what you did here. A BootCamp install creates a special folder to hold Windows environment in a VM space. A raw install is when you treat the Mac system as if it where a Dell/HP laptop but you made an isolated partition to run Windows vs MacOS.
Оценка 1
Добавьте свой ответ
James Rough будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 871
