Toyota Tundra 2005 ext bed car shakes/rattles when accelerating
My vehicle tends to shake when accelerating at certain points. When hitting 20 mph the car tends to shake then when I accelerate or let go of the pedal it stops and doesn’t occur again. Same happens when I hit close to 30-40mph. I brought it to a dealer to see what codes appear, according to them nothing pops up. If feels like when the gear switch during accelerating speeds it starts to shake. What could be wrong with the car?
Update: Issue turns out to be with transmission. Need to be cleaned out and inspect for clogging. Otherwise, the transmission will need to be replaced in the vehicle.
Это хороший вопрос?
1 Комментарий
U might have a bad shaft bearing....if ur taking the time to change it u might as well do the u joint's also.
из Faustino Rafael Gutierrez
