My adaptor is not Working.
i have a Magsafe 60w. i dissemble it to check it from inside . i have found a one 8 pin ic is burnt out and one resistance. now help to repair or reuse this again for my macbook pro.
Это хороший вопрос?
Это хороший вопрос?
I found a video for doing the repair. Warning - It's ugly : http://www.youtube.com/watch?v=20vLvXUfr...
I really recommend replacing it.
Был ли этот ответ полезен?
i cannot watch it it said contained a malformed video ID.
Here's about ten videos on fixing it: http://www.youtube.com/watch?v=20vLvXUfr...
https://picasaweb.google.com/simran.sing...
check this
I am just going to saythis
you need a dremel to open it and clean up the burrs on the case
you need a good glue to seal the case after and still make it look remotely descent after
In all honesty, replace it if you can, ONLY fix it if you cannot afford a new one and if you do, follow my tips above to make it as clean as you can
Once again, you will need a thin dremel tip to open it and you will need to solder, and after that, a grinding wheel to get rid of the burrs after as much as you can and duct tape or super glue
Any idea of anything fixable on the inside?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,541
2 Комментариев
do not try to fix the power supply fro your magsafe just buy new one
из baboba
@baboba...What happens if you are in an area where you can not just buy a new one? Is it possible to repair it?
из oldturkey03
