MacBook Air screws are protruding into the inside of the laptop
I was moving and put my MacBook Air into a box of electronics where it was kept in a laptop sleeve. Today I took it out and I noticed that two screws on the bottom of the laptop are protruding through the laptop and are sticking into the inside of the machine. The machine still works fine however the trackpad doesn’t click down. The screws themselves are protruding through the bracket (not sure if this is the right word to use) that prevents them from being screwed in any further. How do I go about removing the screws?
Это хороший вопрос?
1 Комментарий
Basically the battery is pushing the cover from the inside cause this! Stop using your system and don't bounce it around as the battery inside could explode.
из Dan
