False report of low battery then disconnect?
Hi iFixit,
My controller was working normally then it developed the following fault:
Controller ring of lights report that the battery status is low even with new batteries, every 15 mins approx the controller will then disconnect.
I have tried the following:
Many sets of rechargeable and normal batteries. Using the battery case from my other controller. Syncing the controller to my PC. Swearing at it.
The fault stays the same, cannot find any similar problems on the net. Thought it was a loose battery case but its not.
Thanks
Это хороший вопрос?
1 Комментарий
Got my screwdriver set, on opening the device all connections seem ok. The soldering on the board was surprisingly sloppy considering the name badge! I noticed some white deposits on the board, I gave the whole thing a clean with isoproponol. Sadly still the same, i give up. I suspect its due to a falling component on the logic board.
из Karlos
