No power, no diagnostic LED's!
I know someone almost had the same exact problem as me but not sure if they ever fixed their problem?
So my Mac wouldn't turn on, no chime, no fan, black screen. Read the unplug power source from back of unit and plug back in, didn't work so I unplugged the cord from the wall and gave up for that time being.
One of my kids plugged it back in not knowing a few days later and voila it worked! Although it only lasted for a couple days then went dead again.
I tried doing all the same things and nothing. Then I started researching everything I could. Ordered a new power supply which everything led to but no dice. I then figured out how to test the power supply with a multimeter and there is power so that is good.
Learned about the diagnostic LED's but mine has none.
When I do unplug the power cord from the back of the unit and plug back in, LED #1 blinks once then goes off, like a flash more like it. Only sign of power I am getting.
Read more about everything and removed the hard drive, reinstalled the PRAM battery, etc and still nothing! Assuming it's the logic board at this point unless someone has a magical trick that may have worked for them?
I have not tried removing the video card yet which some people say may be causing the short and needs to be taken out to reset. Just didn't feel like taking everything back apart if that's not the problem.
I did look at both the logic board and power supply and don't see any blown capacitors with the naked eye.
I guess my question is, is there a video that can show me how to find the short in the logic board with a multimeter for my exact machine? I saw one video in Hindi I could not understand but was not the same exact logic board.
Any help/suggestions would be great!
Frustrated!
Это хороший вопрос?
