What does F H flashing in estimated time remaining mean
The letters F H alternately flash in the estimated time remaining
Это хороший вопрос?
Это хороший вопрос?
FH (Water Inlet Problem--no water or insufficient water supply)
Check/Repair:
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
For more information as well as help for any repairs, you can download the service manual from the bottom of this page under Documents.
Let us know what you find.
Был ли этот ответ полезен?
“The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop.”.
How to fix the flashing F H code on an Kenmore washing machine
F11 same washing machine
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 1,388
1 Комментарий
What does f11 mean?
из Tiffany Hayes
