Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1961 Questions Показать все
recovery mode after a succesful restore...
There is NO error, it restores normally but when its over, it says it worked fine
the phone reboots and its in recovery mode. i repeat all this and still wont reboot.
I got the phone today and it was working fine.
i opened it and it has water damage i said ok the phone seems to work so no problem. i refurbished it completetly and when i turned it on it didnt work :(
Any ideas?
home button didnt work prior to restoring...
im assuming i either damaged it or its just the water damage acting up
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Комментарии:
did you replace the battery as part of your refurb? which parts have you changed?
от
i replaced the housing and the screen
от
Добавить комментарий
Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
4 Ответов
Выбранное решение
Jonas, I would go ahead and follow this guide Electronics Water Damage just to make sure that you wont have any issues with the phone down the line. To get it out of recovery mode I use Recboot.. Good Luck
Был ли этот ответ полезен?
по рейтингу 2
Комментарии:
I have an iphone 3gs 16gb that was unlocked and recboot is not working to get it out of recovery mode
ive used redboot to kick another 3gs out of recovery but i seem to have no sucess with this one.
when i restore it it gives me error: 28 on itunes
do you have any suggestions?
от
Unknown error 28
Problem restoring your device (Problem Irreversible)
Solution: None.
Contact Customer Service for Apple iPhone replacement (if it is still under warranty)
These errors may indicate a hardware problem of your device. Follow the procedures described in this article and also try to perform a restore by connecting to a computer and a network that you know, to isolate the problem to the device.
If the IMEI number or the MAC address is not specified or corresponds to a default value, it can also confirm that the problem is of a material.
some people have had success by changing the dock connector...
от
Thank you so much, recboot wasnt working until i clicked on Exit and thats the only one that opened up and it just kept rebooting the phone on and off im like uhhhhh so i disconnected and it started doing something i never saw before and boom it was restored lol.
thank you! your the best btw:)
i will try this on other broken phones stuck in recovery now :)
по рейтингу 0
Have you tried it on other phones, does it always work or are some just not goin to fix?
по рейтингу 0
The easiest way to exit iPhone Recovery mode - ReiBoot. No need of home/lock button, no need to connect to iTunes. Only one click to exit iPhone Recovery mode.
по рейтингу 0
Добавьте свой ответ
Jonas будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 5,093
