Apple's 6th revision to the iPod Touch lineup, released in July 2015.
149вопросов Показать все
Charges fast and dies fast
Hey I have a iPod touch 6th gen come in for repair
anyways, this is the third one that came in wasn’t charging or turning on… so I decided to change the battery and re solder a new one in. It’ll charge very quickly and drain fast as well. I’m not sure if it’s the batteries I am getting off eBay or if something hardware is at fault on the logic board causing this issue. Is this a U2 IC Failure? Any shops that have this same problem it would be great if you could chime in with a Solution. It also recognizes with the computer and charges at 0.72 volts
Это хороший вопрос?
Оценка 2
Добавить комментарий
Ответов (2)
Try the battery that iFixit sells.
iPod touch (6th and 7th Gen) Battery
iFixit generally has decent quality batteries.
iPod touch (6th and 7th Gen) Battery Изображение
Продукт
$19.99
Был ли этот ответ полезен?
Оценка 0
ipods generally have a terrible battery life,
Оценка 0
Добавьте свой ответ
Daniel Ringuette будет вечно благодарен.
Просмотр статистики:
За последние 24 час(ов): 0
За последние 7 дней: 10
За последние 30 дней: 18
За всё время: 2,461
