LCD touch don´t work
Replaced LCD on iphone 7. Part of the screen don´t react when touching after replacement.
Это хороший вопрос?
Это хороший вопрос?
This is likely because you either damaged the replacement screen, you got a low quality replacement screen or the display cable isn’t properly connected. Try reconnecting the display cable. If that doesn’t work, replace the screen.
Был ли этот ответ полезен?
Did you replace just the LCD or did you replace the entire front panel (Digitizer and LCD)? You might need to reseat the cables on the logic board or if you bought the digitizer and LCD combo, you might have gotten a bad part.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 26
