How to restore iPhone from recovery mode?
how to restore iphone from recovery mode
Это хороший вопрос?
Это хороший вопрос?
just plug in the phone via usb cable and try to restore the phone but you must have a internet connection. restore need a software file (version=4.3.3) 660mb that will downloaded automatically . if you are stuck in the loop then remove the back cover and remove the battery plug for 5 mins then restore it .
Был ли этот ответ полезен?
tried that , didn't work
can't restore in Itunes receive error message 1015
that's a common error for a jailbroken device that apple won't recognise. Google the solutions for either mac or pc-should be straightforward.
Connecting to iTunes and click restore will erase all the data and setting on iPhone. If you don't have an available backup to restore from, you'd better not do that. The tool ReiBoot is used to exit iPhone recovery mode with one click, without resetting iPhone and connecting to iTunes. Have a try if needed.
You may try this iPhone Photo Recovery, which allows you to recover photos from iPhone directly, see a guide here:
To get iPhone out of recovery mode, I'm afraid you'd turn to some professional software to help you. Or you can simply refer to the guidance here: iPhone Stuck in Recovery Mode & How to Fix
Here is a quick guick on how to fix iPhone stuck in recovery mode:
1. Lauch iTunes (make sure you've installed the latest iTunes).
2. connect iPhone to computer via usb cable.
3. Wait for iTunes to recognize your device. An iTunes popup will display that offers to restore your iPhone using your most recent backup.
4. Click OK to exit restore mode.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,651
3 Комментариев
have you tried connecting to itunes and clicking on restore? or are you stuck in bootloop?
из pollytintop
what error itunes giving when trying to restore?
из gts
thnk u so so much
из Bibi Farwah
