Выпущенный 16 сентября 2016 года смартфон нарекли iPhone 7 Plus. Вышло несколько моделей нового устройства: A1661, A1784, и A1785, а также можно было выбрать между версиями на 32, 128 и 256 Гб встроенного накопителя. На выбор можно было приобрести золотой, розовое золото, серебристый, Jet Black и (PRODUCT) Red оттенки корпусов.
1364вопросов Показать все
Audio and Selfie Camera Not working
I am looking to purchase this iPhone for 110 dollars, because I believe, per the description, all that should need to be fixed is replace the screen and the front proximity sensor, correct? Please see the device description below.
  1. The device has a cracked front glass, but there is no LCD damage to the screen underneath.
  1. During a phone call, the device's user is unable to hear the other party when holding the phone against their ear.
  1. The front camera (commonly referred to as the selfie camera) is not operational.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
It could be just the front facing camera flex also known as proximity flex.
There is also a common issue with the 7 series phone that causes no audio due to having a fracture under the audio ic.
I would be careful with this purchase
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
I have a contact that can fix the audio ic issue for 65 bucks, that was my other thought, but even so, with the 65 and 110, the 7 plus are going for anywhere between 330 and 515 on swappa right now.....do you still think it is a bad idea?? I am new to this whole buying, fixing, and selling process, so any input is much appreciated.
из
Hard for me to comment on pricing as im in Australia, if i convert that to AU that works out to be about 240au so i reckon that's a good buy.
из
Добавьте свой ответ
Rachel Kelley будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 140
