Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
211вопросов Показать все
Can I repair broken IR and Fan connectors - sheered off at logic board
I have a Mac mini mid-2011. I installed an SSD as the second drive.
It works but I have broken the IR and Fan connectors - sheered them off at the logic board.
Is it possible to repair these two connectors with “micro-soldering”?
What tools do I need to do that please?
Это хороший вопрос?
Оценка 0
Добавить комментарий
LCD iPhone Screen Fix Kits
The budget option, covered by our Lifetime Warranty.
Shop Kits
Cut repair costs, not quality.
Shop Kits
2 Ответов
Наиболее полезный ответ
@cooker47 that will depend on how they are broken and if they destroyed the solder pads. If so, you will most likely have to run some jumper. There are no schematics or boardview for the Mac Mini so that would mean it could get tough. If the pad are still decent, you can resolder the connectors (or buy new ones if the originals are destroyed). Take a look at the answer I popped off the fan connection from the logic board...Fix? and see how to solder it. Different connector, same idea. Post some images of our damage so we can see what you see. Adding images to an existing question
Был ли этот ответ полезен?
Оценка 3
I would directly solder wires to motherboard
Оценка 1
Добавьте свой ответ
Michael Cook будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 126
