THE FIX IS HERE:
No matter what refrigerator you may have, I believe, what I am about to tell you will fix this problem. I have LG refrigerator and have had this problem of "Ice maker on the door making ice, but not dumping it, unless I pressed the reset button” but that is not the solution, it is frustrating! I had this problem for couple of years. I finally got an expensive extended warranty to tackle this issue.
they sent three different teams to fix this problem with no success. they changed the door ice maker, the craft ice maker on the bottom freezer, and even changed the motherboard and they tested the crap out of the system to no avail.... Finally, it happened, on the 4th go around the technician spoke with the LG Engineer and what he did FIXED the problem:
The reason that door icemaker makes ice but doesn’t drop is the high temperature.
- The lower icemaker vent to door icemaker are does not provide the cooler temperature.
- Behind the fan on the bottom icemaker where the colling fins are, is iced up and therefore cooling which is provided by the fins is restricted, hence not enough cool temperature reaches the door icemaker are, and the sensor does not allow the ice to drop in the bin, because it does not sense the proper (lower temperature).
- So there are two ways to fix this problem:
o Thake the cover off of the lower icemaker and using hair dryer melt the ice where the fan suppling the cold temperature up to door icemaker is.. or if it is too difficult to do so,
o Empty the refrigerator (by moving all your stuff to anther refrigerator, or cooler) an open the doors of the refrigerator and let the ice melt that way.
I hope this solves your door icemaker problem.
Ken
Был ли этот ответ полезен?
Проголосовали
Отменить
Счет
0
Отмена
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
39 Комментариев
Thanks. Thermostat seems most likely. I’m leaning toward replacing the whole module since it looks simple (5 screws) and the module runs just about ~$120 on Amazon. Plus my fridge is 5 years old and people say that’s about how long the icemaker lasts anyway. I called a licensed LG repair place and they wanted $500 for a new unit and $200 to install it. Big NOPE.
из bannisterthomas
I have the same problem. Ice maker only dumps manually. I replaced the ice maker. Same problem. Freezer set to -6°F and Fridge set to 35°F. Ice freezes fine. No dump. I get the thermostat issue but, on a new maker and same as old unit? Ice maker is AEO73110210. Fridge is LMXS30776S /01
из hapersson
@hapersson Have you checked the temperature at the ice maker? The display shows what the temperature is set for but that might not be what the temperature is at the I/M. The thermostat is located on the bottom of the tray. It moves when the tray moves to drop the ice. Moving plastic parts will break often. Dirty condenser coils will cause the icemaker to slow down or stop making ice. The coils should be cleaned once a year. More often if you have pets.
If you have below 9*f at the I/M and the coils behind/underneath the unit are clean and the tray fills with water, then you have a problem in the I/M. A gear could be damaged, the tstat isn’t sensing the temp correct or the wiring to I/M is loose or damaged. I’ve had many brand new parts that arrived damaged. Especially ice makers. Parts will come with a warranty. Just because something is new doesn’t mean it won’t break.
из LadyTech
@ladytech Thank you for the reply and suggestions. My compressor and coils are good. Just had the bad linear compressor replaced by LG. I put a digital remote probe in the ice maker compartment in front of the probe. The temp has stabilized at 26°F. I removed the ice maker pack and added insulation behind the temp probe and reinstalled the package. Now we wait...Thanks!
из hapersson
@hapersson 26*f is too warm. The ice maker won’t advance until its 9*f or below. If it doesn’t go believe 9*f you should call LG while the repairs are still under warranty. It could be a problem in the sealed system foe why the temperature isn’t reaching temperature. You should check the fresh food section temperature all so.
из LadyTech
Показать ещё 34 комментариев
