DISHWASHER FAULTY TIMER SWITCH REPAIR
The #1 Problem with Dishwashers
A faulty timer switch is often the cause of dishwasher breakdown. This very important switch is basically the brains of the machine, controlling various wash cycles, while automatically regulating the length of time for each cycle used.
How do I know if it's a faulty timer switch:
- Machine will not turn on (circuit breaker and fuses are okay).
- Machine runs through one or more cycles, then stops.
- Machine continues to operate on one cycle and will not switch to the next one.
Don't worry, "Dishwasher timer switch replacement" is a fairly simple task.First, check the dishwashers make and model number. Buy a proper replacement switch from a local dealer.
You will see that the timer switch has a number of wires running to and from it. Reconnecting them will be much easier if (before you remove the switch) you draw a diagram or label the wires so you are certain where each will reattach to the new switch assembly.
For problems that appear NOT to be related to the timer switch or cannot be solved by the simple repairs mentioned, it is probably time to give a service person a call.
Be sure you know where each wire needs to go before removing the timer switch. UNPLUG DISHWASHER BEFORE TOUCHING SWITCH! | Source
UPDATE
No timer? Then it's controlled by the main board:
https://www.repairclinic.com/PartDetail/...
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
2
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
13 Комментариев
Hi @creiter2 ,
Check on the inside of the front panel to see if there is the service data sheet for the dishwasher.
If it is there, hopefully it will tell you how to get into the 'diagnostic mode" and if so, what the results mean.
из jayeff
Ok. There a sheet of paper there, so I will look.
Thanks
из Curt Reiter
Ran service test, and after it was done i opened door and closed it then the air dry and high temp wash lights were flashing. This indicates a power failure has occured. Everything (dispenser, heating element, etc) worked during test.
из Curt Reiter
Hi @creiter2 ,
Did you try to reset the dishwasher after you ran the diagnostic mode by disconnecting the power for at least 5 minutes?
из jayeff
Just ran diagnostic mode, shut of power for 5+ minutes, switched power on and air dry and high temp wash light came on again.
из Curt Reiter
Показать 8 больше комментариев
