How do I make the second monitor active if primary is down
Normally I would use Command F1 to make the external monitor active but there is no F1 key on the touch bar. Also the screen is broken so i can’t get into system preferences on the primary display. Need to turn off autoboot before putting new display on.
Это хороший вопрос?
8 Комментариев
Won't removing the battery prevent the Mac from turning on whilst repairing it?
из [deleted]
see step #1 Step 1 Disable Auto Boot on this guide. Just trying to follow directions
MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement
из mayer
I got the bottom off without activating the power on. Not easy!
из mayer
@mayer I'm at a loss of understanding that removing the lower case could trigger the fastboot?
из [deleted]
Obviously somebody did it or it wouldn't be in the guide. Lots of things get put in guides because someone had to first do it wrong.
из mayer
Показать 3 больше комментариев
