Wii will not turn on
Hello,
My Wii will not turn on.
I plug the A/C adapter in the power outlet and check with a multimeter : I get around 12V.
Now I plug the A/C adapter in the Wii and the light doesn’t turn red. If I unplug the power adapter and check the voltage, I get 0V. If I let the power adapter sit disconnected for 2 minutes to reset it and try again, it goes back to 12V, and back to 0V as soon as I plug the Wii.
Do you know what could cause this issue?
Это хороший вопрос?
Hi @alamaree
Most probably inside Wii there is some shorts.
as a precaution the power adapter will shut off to prevent further damage to both.
you will need to access to the mainboard section to inspect the components
из Augustine
What do we do from there if the circuitry within the wii is a problem?
из Hunson Abadeer
