Repair guides and support for your Samsung TV.
2387вопросов Показать все
Samsung LED Smart TV Red Light Blinks 5 Times UN60H6350AF
I have an UN60H6350AF Smart TV that when pressing the power button the red light blinks 5 times and goes out.
I have opened up the TV and when I unplug the main board from the power supply I see the LED light come on. Makes me believe the power board is fine. How do I determine if I need to replace or fix the Main Board or T-Con Board?
Thanks in advanced.
Это хороший вопрос?
Оценка 3
1 Комментарий
I have the similar problem I have changed the t-con board and the power board with new ones and still not functioning
ng any help would be great
из
Добавить комментарий
2 Ответов
Выбранное решение
I replaced the Main Board and everything worked! Thanks.
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
@masterethan
it’s a bit like guessing. I would check to see if you have power on the BL-En on your connector. That is the power to enable the backlight by the power board. If you have that then it is most likely the t-con board. Check the fuse on the t-con board for continuity and voltage. You should get ~12V on that.
Оценка 2
1 Комментарий:
When I unplugged the main board from the power board, the screen lights up and I can see the light coming through the screw holes as well. With that I assumed it's either Main Board or T-Con, but wasn't sure how to determine which one it was. I'll find and check the t-con boards fuse and voltage and see if that reveals anything. Thanks.
из
Добавьте свой ответ
masterethan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 41
За всё время: 8,688
