My RCA 65 inch smart TV doesn't show an image anymore
Hello i have a RCA 65’’ smart LED LCD TV 1080p SL65A55-A201083. It was working fine then it would only come on after several attempts. Now there is no picture but there is a red light on the bottom. I have tried holding the power button tried the reseting the tv with the power and volume button so far nothing works. I do have voltage at the board. Can anyone help me with this problem? This is the second site i have asked this question and no help at all. wow. Thank you for your response. I have checked those things but everything looks good. Im also not sure which board is which. Could you tell me which board is the power board and were i might be able to order it and which number would i use on the board when ordering it. Thank you so much for your help.
Hi i checked both fuses and they are good. There is 5 volts coming out of the board going to the other board. Also the other board with the hdmi rca connectors on it there is also 5 volts coming in the board and 5 volts in other places on that board. The red light stays on continuously even when you press the power button. I checked the power at the power button and it has that 2 volt continuous and when you press it it goes to zero. Hope this is helpful and here are a few more pics.
Это хороший вопрос?
2 Комментариев
How much does a cxd4737gb cost, and have the same problem 65" Sony flat screen TV could that be the problem
из Bobby Cruz
Hello I’m having an issue with my RCA sld65a55gq can someone help me please?? I turn the tv on and there’s no picture. The back lights come on but nothing. I can see the blank screen.
из john tabor
