The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
158вопросов Показать все
Hdmi port failing in Xbox one X
It works, sometimes, I have to tweak the cable to a certain angle for the connection to fully work. I just need help finding a quick tutorial on how to replace it or reseat it.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
The HDMi Port is soldered to the main board there is no easy fix for this unless you are able to solder, Have you tried another HDMI cable ?
If that dosnt’t work try cleaning the port with a cotton Bud and some rubbing alcohol if you have it.
Был ли этот ответ полезен?
Оценка 0
I don't have an answer but , I have the same problem. Sadly now it completely as stopped working .
Оценка 0
Добавьте свой ответ
Phoenix будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 2,717
