1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371вопросов Показать все
How to test if logic board or battery is issue? (MB Air 13" mid '12)
My MacBook Air Mid 2012 recently stopped working unless plugged into the charger. The battery appears to have disappeared, though Apple Hardware Test doesn’t find any faults. Coconut battery doesn’t find anything and the System Information produces:
Battery Information:
Charge Information:
  • Charge Remaining (mAh): 0
  • Fully Charged: No
  • Charging: No
  • Full Charge Capacity (mAh): 0
Health Information:
  • Cycle Count: 0
  • Battery Installed: No
  • Amperage (mA): 0
  • Voltage (mV): 0
SMC and PRAM resets have done nothing. Does anyone have any experience in whether this is likely to be a battery or a logic board issue? The battery was replaced in May with a third party battery. Is there another test I can do other than buying another battery?
Thanks,
Sam
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
The micro controller within the battery is not responding!
Which is why the system is not seeing it. Sorry, you’ll need to replace the battery. Given the age of the system it’s likely well worn as well.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Cool: thanks. I wasn't sure which it was.
I realise the system is old, but it is a favourite!
из
Добавьте свой ответ
Sam будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 7
За всё время: 118
