Motorola razr v3 wont boot strange message on screen
I have a razr v3 from 2004 whenever I Try fo boot it up I get a weird message is there any way I can fix this. Here is the message
Boot loader 08.26 SW VERSION R374_G_0E.41.C3R_B OK to program usb transfer mode phone code SIG 35:02:
Это хороший вопрос?
3 Комментариев
Thanks for your awnser, do you know where I could find the software to reflash the phone? Also if it helps I'm in canada and the phone was bought from Rogers in 2005. Rogers is the only network in canada that still has a 2g signal.
из Panayiotis Michalos
It's going to be very difficult. Unless you can find it on a forum that's been around since the Java OS era, it's going to be difficult to find the tools and file to flash. I'm not sure how SIM unlocking works if you have the international ROM, so get the Rogers ROM before you even consider flashing the international one to the phone if you want to get it done. You may even need a Windows XP system if the software doesn't work on a modern OS.
I don't think T-Mobile will continue to support 2G too much longer once 5G becomes more widespread.
из Nick
Ok I'll try to find a Rogers rom if you happen find something please let me know
