Released March 2016, the Rift CV1 is the first consumer-targeted virtual reality headset by Oculus.
Can a Scratched Lens be repaired or replaced?
I have some scratches, resulting form wearing glasses while using the Rift. After getting prescription lens adapters the scratches are more visible. The scratches not deep, but are more of a rubbing of the Oculus lens and my glasses len. The result is a slight cloudiness in one eye. Just enough to make it annoying in certain situations.
Is lens replacement some thing I or you can do? Oculus Support said I would have to get another set, but generously offered me a refurbished set at a 20% of the retail price.
They can drop dead.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
This happened to me too, you don’t actually need to replace the lenses, the solution i did was easy. All you need is a lint-free cloth, a non-gel toothpaste ''(i would recommend one with baking soda because it works better), and a damp cloth. First, clean the lens well and dry it using a lint-free cloth. Apply a dollop of toothpaste to a soft cloth and rub it into the scratch using a circular motion. Then, use a slightly dampened cloth to clean away any leftover toothpaste. It doesn’t fix the scratch but should hide it.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Chris буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 2,063
