The Hover-1 Liberty is a self balancing e-scooter or hoverboard. It has a max speed of 7.4 mph, a max weight capacity of 160lbs, and it can travel 3 miles on a full charge. It also comes with LED wheels and Bluetooth capabilities. Model: HY-LBTY.
Wheel does not seem to be straight
The one wheel on my daughters hover board is not straight and moves quite a bit compared to the other.
When I opened it up there were little black bits ??? Compared to the other side it looks like a plastic clip is missing?
Is there a way to staibilize the wheel? Hover 1 won’t help us due to the receipt is not with us as it was a gift …
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
I’d first check the bearing. Use a magnet to tell if the bits are metal or plastic.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
all bits are plastic and wheel goes down at last i used only 2 times
из
Добавьте свой ответ
Les hill буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 382
