Repair and troubleshooting guides for the Acer Aspire V3-571G-9686. This 15.6 inch laptop was released in October of 2012.
20вопросов Показать все
Green line in right side of the display.
Hello. I own an Acer Aspire V5-571G laptop, with IPS LED Display, 1080p resolution. Suddenly, a vertical line has appeared in the right side. It changes the color, on white is green, but on black it is not visible. Do i need to replace the display or maybe is just the connector?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi Răzvan Alexandru
well, test with an external monitor /display to confirm the lines is on your laptop display.
you can try reaseating the LVDS cable and see if it helps.
what you are seeing line … most probably the lcd display bonding on your laptop display is not well bonded.
you can try stripping till you see the lcd module, and try applying light pressure to it.
sharing a video, fyi.
https://www.youtube.com/watch?v=UNf81Z-i...
imo the video is a short temp fix.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Răzvan Alexandru будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 231
