Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1500вопросов Показать все
How do I get cable 2 to seat?
I replaced the screen and digitizer but cant get the cable 2 to seat, therefore the touch feature does not work. It is a 3gs, only 6 months old, and the part is supposed to be for a 3gs. It seats fine, but will not stay. please help!
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Выбранное решение
Hi Deb, are you confident the part is for 3GS? The 3GS has a black plastic piece between the metal contacts. You may have to look at some pictures to compare. If this is confirmed and the connector just won't snap into place, you need to make sure there is nothing on either connector that is in the way. Once you have the connector aligned to the one on the board, you press down. One side may go down easier than the other - press with a little force. If this does not work, don't keep forcing it - you can damage the fpc connector on the board. Patience, a couple deep breaths, and a steady hand - you will get it! I hope this helps!
Был ли этот ответ полезен?
Оценка 0
I had the same issue as you. I thought cable 2 was OK but it kept popping off. I finally concluded I wasn't applying enough pressure. Once I did it stayed connected. I'm assuming you have the cable correctly aligned. Check that before applying more pressure. Good Luck.
Оценка 0
Добавьте свой ответ
deb будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 707
