The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1150вопросов Показать все
Black screen on boot after replacing the top lid
I got this MacBook Pro Early 2015 model, The screen is messed up, it still displays picture just the right side is cracked. I ordered a replacement screen and installed it.
On boot its black no display. If I close the lid the Apple logo lights up, then I re-open the lid and the display is fine. If I restart with or without the power adapter it boots to a black screen. I tried clearing the PRAM and EMC. Same issue.
So i reinstalled the original screen and it displays the picture right away just like it should.
What am I missing?
Running Mojave
Update
I did that as instructed same behavior Here are 2 vids i just upload to youtube. I put the original screen back on. Took a video of it then Installed the replacement and took a video of it.
Oringal Screen: https://www.youtube.com/watch?v=zMoNKmnT...
Replacement: https://www.youtube.com/watch?v=a-zvgMXE...
Это хороший вопрос?
Оценка 3
3 Комментариев
Where did you get the display and the P/N you used? Also did you replace the full assembly?
из
Well, the part number is the correct one for your system MacBook Pro 13" (Early 2015) Display. But I think you got this one MacBook Pro 13" (Late 2013-Mid 2014) Display. Which explains why your display is not working correctly.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Double check that these:
are connected properly. You can find the order in step 8 of this guide. Also double check the the LCD cable is connected properly to the screen. Sometimes if the connection isn’t solid this can happen. After all that power cycle the MacBook
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Can you get a replacement?
из
Добавьте свой ответ
mikebarkas будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 220
