Rear window regulator end stop
Passenger rear power window would not work because the regulator frame was bent.
I straightened the frame, reinstalled, and it moved up an down. In the down position,
the regulator stops without releasing the switch, but in the top position the motor tries to continue to wind the window against the stop if the switch is actuated. The regulator on the other windows stop in the both the fully closed and open even though the switch is actuated.
Is there an adjustment I need to carry out? I believe this could be the reason why the
frame got bent in the first place.
Это хороший вопрос?
