Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3530вопросов Показать все
iPhone 5s doesn't recognize SIM Card
Hi there everyone,
I recently bought an iphone 5s which doesn’t recognize any SIM Card put into it. The strange thing about it is that the iPhone doesn’t ask for the SIM Card in the first place. My usual experience with iPhones is that, if you dont have a SIM card inside, there will be a notification telling you that. This time around there’s nothing, which is why I wonder if my problem is possibly slightly different to the normal SIM Card not working one. Maybe its a software error?
Thanks,
Minas
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
There is a “switch” built into the SIM card reader to detect the presence of a card. Normally, the phone should notify you if a SIM card is not present, as you suspect. So the fact that you are not being notified leads me to suspect an issue with the SIM card reader. You could open up the phone and take a closer look at the reader to see if there is any internal damage. The reader can be replaced but it requires a micro-soldering repair.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
Hi and thanks for the help! Could you clarify what the "switch" exactly is? Is it a physical switch that I can toggle? I'd rather not open up the iphone, but will if I have to.
из
Inside the SIM reader, an inserted SIM card forces a disconnect between two metal contacts.
из
Добавьте свой ответ
Minas Mayth будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 8
За всё время: 880
