Does Anyone Know Where I Can get a Capacitor Replacement Kit
My old sources have dried up on finding these capacitor replacement kits. Does anyone know where I can get them or have them put together or a list of what I need to order from Mouser?
I also need a working 400k floppy drive.
Это хороший вопрос?
3 Комментариев
Are you looking to replace the power supply caps or the main board? Or both? Is it the cap kit that 8-Bit Guy offered?
EDIT:
Here's a list of list of high failure probability parts on the main board.
https://web.archive.org/web/200610161023...
из Arthur Shi
@arthurshi He doesn't confirm M128/512K compatibility on the parts he lists. It's only known to be compatible with the Plus.
The majority of 512K parts typically work on a 128K if you need to do it. It's similar to the 128k but with all of the traces present to add 512K of memory (the 128k was limited because Jobs had some of the traces cut since the 128k board IS 512k compatible).
из Nick
I've learned something new today :)
из Arthur Shi
