2006 Pt Crusier heat stopped working and is also overheating
My car is overheating and the heat stopped working! I can Also hear something leaking on the drivers side of the vehicle when i turn it off! Need help!!
Это хороший вопрос?
Это хороший вопрос?
What color is the leaking fluid? is it gold/brown (oil), reddish pink (transmission), green (coolant)
Air in the Cooling System can cause overheating if not purged of air pockets properly if you've had a coolant flush, possible surging.
If your’re not feeling air coming out the vents (cold or hot), its a blower motor relay and/or interior switches (low,med,high) circuits need to be checked, or possibly the blower motor itself.
Был ли этот ответ полезен?
The liquid is green
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,021
1 Комментарий
check your carpet and if its wet there is a good chance your heater core is leaking and the coolant level is now low enough that your heater wont work and the engine does not have enough coolant to keep it cool. you can add water but if its freezing out it will have a greater chance of freezing and causing lots of damage if you just add water. take it to a shop and have them take a look, it shouldn't take long. you might try an auto parts store like autozone and see if they would look at it.
из Dan Dunham
