The Razer Blade Stealth are a line of premium Ultrabooks by Razer. The latest model is the Razer Blade Stealth (2019)
48вопросов Показать все
Cleaned laptop after spilling coffee but still won't turn on
I spilt coffee on my Stealth. I turned it off right away when it happened. I detached the battery and screen and rinsed everything with distilled water. I waited several days for it to dry, but it won't turn on. How can I tell if it's completely trashed, or if there's some way to salvage my laptop?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
In my honest opinion I can’t say it’s salvageable unless you know of someone who deals in micro soldering repairs. By the sounds of things, the coffee and the fact that you used water, even if it’s distilled, means you’ve caused corrosion on the components within your motherboard and they are either damaged or short circuited. This will prevent it from turning on. If you want to learn micro soldering and have some tools, Louis Rossmann on YouTube is a good start, but if not, you will have to send it away for diagnostics or repair or it’ll go in the bin if there’s no warranty / coverage. Sorry.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
kathyjzhang будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 204
