Meter displays OL in voltage continuity mode with or without probes?
Quite an expensive Voltmeter device , did this from day one
OL means ‘over load’ but it isn’t even connected to anything
i suspect it is faulty but wanted to find out if anyone else has experienced this and maybe it’s simple
Это хороший вопрос?
9 Комментариев
It seems to say OL and need power cycle even with no probes attached or both probes attached - even when connected to each other or the same wire.
is there anything I can try ?
из Cristian
Hi @cristianan ,
What is the make and model number of the meter?
из jayeff
Hi @jayeff
It’s a Voltcraft R-200 I purchased from Conrad Electronic
I have written them a bunch of times and to voltcraft but to no avail...
из Cristian
OL does not mean "Over Load", it means "Open Loop". The meter is fine, it is an open circuit, meaning it has no voltage to measure.l
из ronscott64
when I make lighting cable megger test display show OL, what does mean OL?
из hantunmaung85
Показать 4 больше комментариев
