Laptop won't turn on (No fan spinning , No screen)
Hi everybody!
I have an ASUS X540LJ laptop for 2 years and some days ago I tried to apply some Thermal paste (HT GY260) and after I tried to turn it on it didn’t! (I’m not a newbie in computer and I’m absolutely sure I haven’t touched or broke anything on motherboard)
Here are some other information about it:
- both HDD and Battery LED’s work and batteries are full charge now
- After pressing power button, the fan moves a very very bit (Like there’s not enough power to spin it)
I know you’re trying to help me but I’ve already tried many possibilities like:
- Removing batteries , using external display (VGA and HDMI) , testing the motherboard without any batteries, discharging capacitors, USB sockets have power (I charged my phone with USB) , the fan and LED are just fine and work properly (I’ve tested them both)
One told me that maybe the BIOS is the problem, but I’m sure if it’s all about BIOS, the fan should worked and something has to show on the screen when the laptop is on.
I really need your help!
Thanks
Это хороший вопрос?
4 Комментариев
I know this is an old post but I'm facing the exact same problem right now. How did you fix it?
из Ghaith Hatamleh
Hi @Ghaith Hatamleh
Better to ask a new question so people will see it.
из mike
Hi Ehsan, im having the exact problem that you describe in this forum. Did you find the solution or what the problem was. It would be very important knowing your experience to add further information to my case. Thanks in advance. Greetings from Chile
Diego
из Diego Rodriguez
Oh hi :)
Actually at the end, I realized my CPU was dead that time. I hope it is not the same case for you but I gave up on it...
из Ehsan
