Repair guides for the Shure SM58-LC Dynamic Cardioid Vocal Microphone.
9вопросов Показать все
On/off Switch Loose on Mic
Hi, the on/off switch on my new Shure SM58S is quite loose. When I turn the mic on, the switch slides to the off position VERY easily. Is there a way to tighten it - or should I return it and hope the next mic is better? Thank you for any help!
Это хороший вопрос?
Оценка 0
2 Комментариев
This video is the WRONG answer. The question involved an SM-58S wired mic. Not the wireless unit shown here!
из
I am dealing with the exact same issue. Just called Shure to find out about a replacement switch but have not heard back yet. Any luck?
из
Добавить комментарий
1 ответ
Выбранное решение
Hi @jamie70lynn ,
If it is still within the manufacturer’s warranty period, I suggest that you return it for a replacement.
If it is no longer in warranty, here’s a link to a video that shows how to replace the switch.
I cannot find a replacement switch online, you may have better luck.
You could always try contacting Shure and ask if the switch is even available as a spare part.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Jamie будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 14
За последние 30 дней: 30
За всё время: 1,855
