iPhone 6 Plus won't turn on after screen replacement
Battery was connected during replacement. One connector cable for the screen unplugged before I tried turning the phone back on. Display did not turn on. Phone got warm. Later I disconnected the cables. Later I disconnected the battery. I waited then reconnected the battery and then the screen cables and it got warm. I tired to turn the phone on/off. The screen did not turn on. The phone doesn’t respond to itunes or and the screen does not turn on for charging. So I can’t tell if the phone is on or off, but the connector cables still get warm even when not charging.
This has happened before and I left it for weeks and came back later and I plugged it in and it magically worked. I don’t know what happened and I don’t want to assume that will happen again.
Everything worked just before I replaced the screen.
Update (01/20/2019)
Never mind. I plugged the cable into the wrong one. It’s fine. Also, you guys scared the crap out of me. Thanks.
Это хороший вопрос?
